Hi.
How can i open/close hand in TP program in roboguide? TP program, not simulation program.
roboguide hand open/close simulation. TP program.
hsonscyk -
January 12, 2014 at 5:45 PM -
Just call the sim program from your tp program.
dont work Mb other idea?
It won't show up if you just walk through the program on the teach pendant. You have to actually run the sim. That seems to be the only time when roboguide will animate the gripper.
Make sure to check the Collect Profile Data box on the simulation Run Panel to enable the simulation programs.
[flash=640,390]
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.
U try like that?? -
Hi.
This is simulation. But i'm trying to configure close/open hand in TP program. When i'm trying to call OPEN or CLOSE simulation program - simulation file transform into TP program and looks like this :1:!FANUC Robotics America ;
2:!ROBOGUIDE Generated This TPP ;
3:!Run SimPRO.cf to setup frame and tool data ;
4:! Pickup ('box') From ('Fixture1') With ('GP: 1 - UT: 1 (Eoat1)') ;
6:WAIT 1.00 (sec) ;
6:WAIT DI[1]=ON ;
/ENDHow to run simPRO.cf?
Any ideas? -
maybe you need create your macro TP program HAND_OPEN & HAND_CLOSE and call them in main TP?
Quote
Yeah but i must know which I/O i have to simulate and how I have to configure robot.Its possible to call the sim program from tp program... but it's really hard to simulate all possibilities(300-400). It will be great if i can use command like this - "pick closest object"
Did you ever fond the answer? I have the sane problem
Explain more in detail what is your problem. -
In Roboguide
When I make a simulation program I am able to select Pick and Drop and the hand opens and closes.
When I make a simple TP program I tried using :
For Openning I use:
RO[1:Open Gripper]=ON
RO[2:Close Gripper]=OFF
For Closing hand I use:
RO[2:Close Gripper]=ON
RO[1:Open Gripper]=OFF
It doesn't work.. What do I need to do in order to make the hand open and close?
