Hi guys,
I have installed "NetworkConnectivity 2.0.0" on my KRC2.
What is it for? Can I connect to external PC with this?
Regards
Cez
KRC2 NetworkConnectivity
cezex -
December 17, 2013 at 12:00 PM -
That is not familiar. But if it is a KUKA Tech Package, the manuals for it should be present on the robot's D:\KUKA_OPT directory.
Sadly, no .pdf with this....
It may not be a KUKA tech package. Is there a directory for it in D:\KUKA_OPT? If you make an Archive, check the AM.INI file and see if there is an entry. If not, it is probably not a KUKA Tech Package.
This is english part of README.TXT from "network connectivity" directory:
And the KSS software inventory says the package already installed.
Does mean it's from Kuka?"
Setup for KUKA technology package
1. Insert the setup CD
2. Press CTRL+ESC, select "run".
3. Type in the dialog box "E:\setup". Press ENTER.
4. After the corresponding message has appeared restart the computer.
5. The setup has finished after the reboot.
"Thanks in advance
Cez -
I can't tell. Since no one else has chimed in, your best bet might be to check the version # of the package in the inventory and contact KUKA service. They're usually pretty good about providing manuals for tech packages "in the wild."
Ok, I will try to contact them... again.... I promise to tell about their possible response here,
Thanks a lot SkyFire
Cez
