I'm working on my thesis. In the lab we have a Staubli RX-60 robot arm connected to a CS7B controller.
I know it's possible read anytime the position with the command "where". Is it possible read the axis speed, and the accel?
Thanks.
Thanks.
"CS7B" so that means you have the V+ operating system & language (which is obsolete technology). I could be wrong, but I am going to say "no".
I looked through my ancient documentation and I did not see anything to address this issue. I don't believe that the V+ systems had the level of sophistication that would give the instantaneous axis speed, much less the instantaneous axis accelerations.
Ok, thanks.
That's what I thought, but I wanted to make sure.
Check out the ACCEL(number), CONFIG(number), SPEED(number) commands that can be found in the manual.
Write yourself a V+ Program to Display the Values.
