Hello
I have an ABB-1400 M94A with S4 software without boot disk.
So is it possible to share the boot disk of install own.
I'm using baseware OS 2.1...
Thanks...
Boot disk
Uzay -
November 24, 2013 at 12:14 PM -
Uzay;
You need key disk and RobInstall software. If you send to me e-mail with your robots serial number maybe I can help to you.
M94a doesn't have a key disk.
The later Key disk type software (s4c) does not use robinstall, The key disc contained some small files that 'unlocked' the boot packs when loading software.
Robinstall only works with S4c+ controller key string type revision software.Your controller should have boot disks with serial number encrypted on each disk.
If you have an old disk there was an ABB dos program to copy id over to new set of boot discs otherwise ABB could help with new set of disks.
