Any body can help how to connect to NXC100?
For I/O or Data?
Both .We have NXC100 and Robot Arm for wafer handling for repair.
The existing software does not work to initialize the robot arm. I'm trying to re program the software.
The system software is on a E-prom in the controller. You don't need Ethernet for this. Once the robot is running with no alarms you can set up the I/O Ethernet board in maintenance mode. You will have to make a EDS file so the Ethernet board in the robot will talk to the PLC, and remember this is for I/O to and from the robot only. Ethernet for data requires a managed switch and options from Motoman.
In other word, if you are trying to repair this robot your self, you would be better off calling Motoman.
