I am using all the setting found on the forums, I am still unable to communicate to the robot from control logix.
I am able to see the robot in rs networks ( I had to install a eds file )
I am able to ping the robot and use the html status page of the robot
Ethernet/IP RJ3ib and control logix
wes862 -
November 19, 2013 at 8:14 PM -
Is the adapter connection in the robot configured to the same size and active?
Can you ping the PLC from the robot?
Also, I've never worked with CLX, but why does it say Owned:No and Moule identity mismatch on the last screenshot? Is this normal? -
Is the robot set up as an adapter in slot #1 under the Ethernet IP list?
Yes everything is set correct.
I was able to ping the PLC from the robot.I swapped the 1756-ENBT to another card and it started working.
Firmware matched on both cards....
I am guessing I had a defective card however when I went back to the other card it worked.... Unknown why it was not communication however it is now...Thanks for the replies
Wes
