Hi ,
I have ''Error on writing, driver DN2DRV'' error with ''Configuration error I/O driver DN2DRV''.
This happened to me when I was trying to install new HDD with new PC. I had boot problem with OS Cd and I stopped the process and remounted the old PC with old hdd. Normally I was getting this error with old pc with some hardware faults and I was resetting the MFC card to fix this problem. But ALL hardware is same but now I can not fix this problem by resetting that card. I also checked with another mfc card and result is same.
Here is İosys log.
Log Date 16.8.13 : 08:29
open ini-file successful, version 2.00
driver DN2DRV information
object file
driver ready 0
driver version 0200
function entry
input objects 10
output objects 6
driver RSILIB information
object file
driver ready 1
driver version 20000
function entry
input objects 0
output objects 0
driver RSIKDL_ESI_DRV information
object file
driver ready 1
driver version a0000
function entry
input objects 0
output objects 0
IOLINKING: 0 links configured
and I have iosys.ini file and configuration is same and I did not change it and it was working just before above process.
