anyone heard of a device description file to a Lenze Drive Interbus module EMF2113?
WorkVisual/Device Description Files
nuni -
August 15, 2013 at 12:19 PM -
Nope. Did you tried set this module like a KUKA proxy?
yes.i did.
and its behaving really weird.
for instance, if i set it to a proxy of 48 outputs,and connect bit to bit,i raise the first bit and a couple of bits raise on the device.
what is a kuka proxy anyway?
can you explain it to me? -
I'm not 100% sure, but to me KUKA Proxy are generic interbus description files.
When you don't find the proper FDCML, you must use a KUKA Proxy.
The problem is you must know the correct I/O mapping of the device you must emulate with them.
For example, I don't know this Lenze module, but maybe it is configured byte by byte (or word by word), instead bit by bit. And, if so, maybe you have a byte swap.
We handle this kind of problem trying to configure some interbus modules with KUKA proxys.
