I try also conect and I have error. Robot stopped in step in OPEN port? Where is fault?
Your problem is that you are attempting to do advanced KRL coding without learning the basics first. Google "Code Folding." Then read the Programming Manual. Only THEN will you be in a position to be able to use any assistance on sending/receiving XML data.
The OrangeEdit program does NOT load onto the robot. It is purely an editing tool for use offline. It makes it easier to examine KRL code, especially folded code, than on the pendant.
Skyfire
Thanks a lot for your help. I know my basics are not good and this is the first time i am doing this project and i have to submit it by the end of this month
I am reading manuals too but everything is not clear in it for the beginners so i need your help
Yesterday i was trying to send XML string to PC i configured XML structure in configuration file and programming code in XML TRANSMIT but i got error file accessed failed
here r the images
second image
Can anybody tell me how to read the data stream from EKI_GetString
Actually i am able to send data stream from teach pendent but when i sent it from PC then programming is running ok but i didnt find that stream in teach pendent
