I'm having an error, DNET-084 and Dnet-119 board reset failed, board 2 and Dup Mac Ack Fault.
I did the menus, I/O, type, 0, Devicenet and checked the status. The slave is offline, auto reset is enabled but I can't get it to reset. I also took the step of replacing the DNET board but still no go. This robot has been running fine, now I'm dead in the water. Any suggestions?
RJ-3 Dnet-084 error
Chev454ss -
July 24, 2013 at 3:01 PM -
I am facing the same issues, did you ever figure out why you were getting the DNET-119 error?
Comm issues with Wago and DNet board, try changing Baud rate on board and wago to 250 if set at 500 and vise versa. 1 st robot cell gave fits until I changed from 500 to 250 on both places.
DUP MAC ACK Fault after setup and ok comms, Check that plug on wago did not get pulled loose.
These are 2 fixes that worked for me at different times on my RJ2's. Good Luck.
