I own a KR200 with KRC1.
I would like to wire some relay to command venturi suction, vacuum generator and electrical nailer.
Is it possible to do this using X11 ?
Where is the INT[] / OUT[] and physical correspondence documentation ?
Thank you
Thank you
On the KRC1 it's possible as there are physical I/O on X11.
Basically it's just a case of wiring them, the details are on the wiring drawings if they are in the cabinet.
Also you may need to configure IOSYS.INI.
[DRIVERS]
MFC=0,mfcEntry,mfcdrv.o
[MFC]
INW0=0 ;$IN[1-16]
OUTW0=0 ;$OUT[1-16]
OUTW2=2 ;$OUT[17-32]
This will enable the I/O inputs 1-16 and outputs 1-32.
Check the drawings for current limits on the outputs, there are two blocks, one with a higher current limit.
