hello,
i'm trying to get the value of a numeric register with pc developers kit in vb.net
when i use a timer and set the interval at 1000 it slows everything down.
does anybody know how to use the monitor function? i cant get it to work
hello,
to use the monitor function you need a program which establescas conditional to trigger conditions and actions to take depending on your condition signs, then from the program from which you want to monitor using the monitor instruction and the program will ask conditional that will be used ,
after which you no longer want to monitor the signals you will use the monitor Instruction end.
A 1 second timer shouldn't slow anything down. Run your Ethernet cable directly between the robot and the PC. Also make sure that you are only calling one instance of the gObjRobot object unless you renamed it to something else.
Also make sure that your robot program, if it is in a loop has a delay timer to allow the background tasks to operate.
