hı everybody;
ı have a vkrc2 weldıng robot and also ı have connected 2 divecenet ı/o module. one of the moduls ıs on the fronıus weldıng euqıpment (mac ıd 5) and other one ıs for ı/o's(macıd 7). the robot was gave me the 'error when scannıng devıce 2' at fıst days. after that ıt started gave it for device 7. ı realized that backsıde fan vibrating the case much. and ı stopped the fan then the robots work well for a few days. but now my customer called me back because of the same errors.
any idea?
error when scannıng devıce x
basbasan -
June 8, 2013 at 6:55 PM -
Is it on the MFC or an LPDN card?
If devicenet works ok and then suddenly doesn't I've found it's usually down to hardware, loose connections etc
Also trying to transfer a lot of data on the MFC can cause issues.
Sent using Tapatalk 4.
Is everything OK with the terminating resistors?
the resıstor ıs ok.
Last tıme when ı check ı made the connectıon cables agaın. Its mfc cards and one of the devıcenet ıs just for fornıus weldıng machıne and other one connect to 9-10 buttons and 2 barrıers. Thats all -
ıt s ok now. my customers try to change cables way after that the problem came back. ı clear the case wıth the aır and replug the cables and the mfc card. now ıts ok.
