hello sir,
i m currently working with the motoman ma1400 robot with dx100 controller.
currently ss welding opertion is going on that robot.the problem which i m having is that the filler wire which is coming from the wire feeder gets cut from the feeder during the welding operation and gets short on the manipulator body.due to this problem 2 to 3 times the encoder wire got burned totally.i m uploading the photoes of robo and its fixture.hope i will get the reply soon...
filler wire getting cut from the wire feeder and shorting on the manipulator
kishan -
May 27, 2013 at 5:40 PM -
it is obvious that you must fix your wire feeder. if you press it to hard it can break. what feeder do you have?
