Where did you plug the usb stick in?
Replace Hand Teach pendant with computer
Reckless -
April 29, 2024 at 4:26 PM -
Maybe this is a strange idea.
There is an usb connector at the rear of the robot and two usb connectors (A and B) on the teach pendant.
The usb connector at the rear should work and the usb connector on the teach panel only works if an usb cable for printers (A and B) is connected between rear and teach pendant
so basically find firewire type cable hook it to robot and then put usb drive into b on teach pendant? I will try that but it seems super bizarre to me. need to find one of those old printer cables.
As first step I just would plug the stick into the usb a the back of the robot
Tried that last night nothing happened. I believe port was previously used to power a small led light, not sure for what.
