I work on a project with Yaskawa robot GP 7 and YRC 1000 controller. At the same time, I use Siemens PLC to communicate with a robot (communication via Profinet - CP1626). I have one program with default points that are precisely shifted by offsets. To get offsets I use SYSTEM JOB to read values sent by PLC. But I have issues with this solution.The SYSTEM JOB can stop for no reason (my pov). The SYSTEM JOB stops in a line where is a SET statement inside the FOR loop with error code 4432.
I tried to add this SYSTEM JOB as a ROBOT job and also as a job without a group. In both cases, SYSTEM JOBS stops after some time of automatic work.(STARTMODE : AUTO)
Has anybody idea what could induce such behavior?
Structure of SYSTEM JOB in robot looks like:
/JOB
//NAME CALCULATION_R1
//POS
///NPOS 0,0,0,0,0,0
//INST
///DATE 2024/02/11 16:29
///ATTR SC,RW,SY
///GROUP1 RB1
///LVARS 10,40,40,0,0,0,0,0
NOP
'------PART_HEIGHT-------
SET D011 EXPRESS ( IG#(55) * 256 + IG#(56) ) * 100
'------ORIENTATION-------
SET D012 EXPRESS ( IG#(57) * 256 + IG#(58) - 16384 ) * 100
'------OFFSETS-------
SET LI001 59
SET LI002 60
FOR LI003 START= 13 TO 36 STEP= 1
SET LD[LI003] EXPRESS IG#(LI001) * 256 + IG#(LI002) - 16384
ADD LI001 2
ADD LI002 2
NEXT LI003
SET D013 LD013
SET D014 LD014
DELAY 20
END
Thanks in advance for any response,
Sl4w3k
