I've started using iRVision, and I'm experiencing some unwanted movement.
For instance, on the screens, why does the gripper change rotation position while the object is moved away?
Assuming you're using a GPM Locator, perhaps lower the tolerance for rotation to +/- 90 degrees?
It seems as if the vision process identified the shape, but interpreted the orientation of it to be 180 degrees compared to the first picture.
