Good morning. I'm not all the experienced with electrical wiring. I'm attempting to place a non-contact magnetic switch on my Fanuc cage door. My initial thought is that I only want it to work whole the robot is in AUTO. I think I have narrowed it down that I need to wire into the EAS ports on the Fanuc. I will utilize Internal 24vdc/ 0 vdc to power the unit. I'm honestly not sure how to wire the remaining 6 wires from the contact sensor. It comes with two sets of wires for NC (NC1 and NC2). I will only be using 1 set. Can some please walk me through the process. I don't plan to use a safety relay. I have attached a link to the safety switch I will be using.
https://cdn.automationdirect.com/static/specs/idemrfidsafetymglm.pdf
