Assigning value to a KAREL variable in TP program
  • coffeeBean
  • February 7, 2024 at 9:41 AM
  • coffeeBean
    18
    I am wondering if this is possible and I'm just doing something wrong, or if I'm trying to achieve the unachievable :smiling_face:
    I couldn't find an exact example on this in the manual, but I want to assign a value to a KAREL variable in my TP program, fx:
    $[PROGRAM]VAR=R[10001] ;
    However, when I try to run it, I get "Parameter not found" error. I'm puzzled by this, since both $[PROGRAM]VAR and R[10001] have been used earlier in the program. I've also used the current value of the $[PROGRAM]VAR to assign it to a different register, and that works fine:
    R[10002]=$[PROGRAM]VAR ;
    Can this be done and something is missing in the syntax?
    Thank you in advance.
  • hoitzing
    24
    128
    • February 7, 2024 at 12:37 PM
    It works for me, using the actual registers and not local registers. Have you checked when trying to assign from a (non-local) register or from a constant value?
  • coffeeBean
    18
    • February 7, 2024 at 1:05 PM
    Thanks for the reply!
    Quote from hoitzing
    I have not tried with either, since my goal is to use the value stored in local registers and avoid writing to actual registers :frowning_face: Perhaps there is a limitation to this operation that prevents it from working when using local registers?
    The workaround I ended up doing was create a KAREL program that would be called from the TP program with two arguments - an integer which is used to distinguish which KAREL variable to change and a value to be applied. Since there were a couple of KAREL variables I wanted to apply this operation to, I use the first argument in an IF statement to determine which one is to be changed.
    At least for now it seems like moving this operation to a KAREL program and calling it from the TP program is the only way to achieve this.
  • hoitzing
    24
    128
    • February 7, 2024 at 1:14 PM
    Just checked and local registers work fine as well. Doublecheck if you have enabled all the local registers you're trying to access (and not only R[10001]), or dumb typos in the parameter name. Otherwise I don't know where it could go wrong for you
Similar Threads
  • KRL to KAREL match cases
    • Latoff
    • February 13, 2020 at 9:52 PM
    • Fanuc Robot Forum
  • tp
