My teaching box (P6-TB-TE) it´s in Japanese language, How can I change the language?, the robot I´m using is Mitsubishi RV-E2 and controller CR-E116
Mikeq180 -
February 1, 2024 at 6:25 PM -
Nation
February 1, 2024 at 6:28 PM Approved the thread. -
Hi!
I have the same robot controller (CR-E116) at the Uni I am studying at.
While I do not know the specifics, I can tell you what I found when searching for another function in the controller: there are no manuals, and nothing I could find about this specific controller, so I had to bruteforce and "press random buttons until something works".
You can set the controller into "programming mode" by following this procedure:
1. power off via the black button
2. hold STOP and RESET buttons (if this combination does not work, you can also press START and STOP)
3. power back on via the black button
3. release the buttons
5. the controller will beep continuously to indicate that it is in programming mode
You navigate the menu by start and stop I believe, and reset selects. The menus are (undocumented), the only one I know about is "U", which sets the robot's model (option 5 is E2, option 6 is E3J). I know that I changed these menus randomly trying to find the robot model change menu, and accidentally changed to korean. Not sure which menu it was, though.
Hope this helps!
Cheers,
Alex
