Hi guys. I am setting an R30iBPlus master using profibus Wago 750-343 module. I did the follow sequence:
In Master Salve parameter:
Enable
Set the adress
Set the use param data bytes
Set data bytes
Set the config data byte
Set config bytes
(The data in gsd I use the Anybus Profibus Net to read.)
Set the dipswitches in module
Is there anything that is Lost in this sequence?
There is a prof 017 slave disconnected. I checked the cables and terminal, but its ok.
I tried to use Just 1 output module ( 750-504) to test this comunication but It doesn't work. Is there any Idea about this fault?
