When I try to detect the controller using Ethernet controllers on srs (making sure PC's ip is correct), nothing will be detected, and when I try to upload a program using an USB an error in the function call will appear:
"Invalid application: check program parameters in call() or spwan instructions."
I think it may be because the controller version when I created the program on srs was 7.11.2 and the version of the cs8c controller is s5.1.1.
I was wondering if this is the issue (this is my first time working with a robot but it makes sense if it is the cause of the problem) and if it is so, how could I update the controllers version, because I can't find the VAL3 language version release I need to install.
Any help will be appreciated.
Thank you!
