  4. Stäubli & Bosch Robot Forum
Staubli cs8 controller startup application without MCP
  • Dominik Wenesz
  • November 9, 2023 at 3:38 PM
  • Dominik Wenesz
    Hi guys,
    I'm working on a Staubli Ts2-40 scara robot using the cs8 controller.
    I want to test my ROS based communication via ethernet cable. (I want to control the robot with a Jetson Xavier NX)
    (server side VAL3 appication on the cs8 controller)
    My problem is that, I dont have an MCP for the controller, so I have to load the VAL3 app via FTP, and also change the configs via FTP.
    My question: how can I configure the controller via FTP to autostart my VAL3 application? (VAL3 app is already in the usrapp folder)
    Thanks in advance,
    Dominik
  • Fubini November 9, 2023 at 3:39 PM
    Approved the thread.
  • Galet
    19
    141
    • November 9, 2023 at 7:04 PM
    • Best Answer
    Hello Dominik,
    TS2-xxx... use CS9 controller, TS-xxx... use CS8 controller.
    For the both, the property autoStart is in the file "usr/configs/cell.cfx" (in the example "StartAppli" :frowning_face:
    <String name="robotName" value="" />
    <autoStart name="StartAppli" location="Disk" />
    <String name="initWorkingMode" value="remote" />
    Be careful when you change file with ftp connection ...
    If your controller is a CS8, you can connect your PC with SRS and RemoteAccess licence ! In this case, it's really easy to change the autoload application without any risk.
    Perhaps there is other solution...but I don't know it...
    Have a nice day,
  • FTP
  • staubli cs8c
