hello I have too crx-10 both with glue gun head and a cable that is pretty heavy about 5 pounds the issue I am having is every time i try to run the part the gun gun cable when pull to much in different zones causing the payload to fail. my question is their some variable i could set on something in dcs to solve an issue of once payload is set have a tolerance or something of that kind of idea note operators will be working with robot also tried calling multiple payloads
CRX-10 payload issue with current config
kubiac1017 -
August 9, 2023 at 4:28 PM -
Lemster68
August 9, 2023 at 4:34 PM Approved the thread. -
- Best Answer
B-83744EN/05 is the manual you're looking for on Fanuc E-docs. Page 55 is where the variable payload compensation section begins.
thank you so much worked perfectly
