what variables carry extended axis values
  • jstolaruk
  • July 7, 2023 at 5:35 PM
  • jstolaruk
    16
    189
    I've got (2) extended axis (J7 & J8) that I make a dual axis after I calibrate them (J8 follows J7) so after pairing, a PR will only show J1-J7, I've noticed that if J8 (or J7) suffers a over current fault (requiring the controller to be power cycled) and J8 is no longer zero when J7 is zero, there are no faults indicating that they are no longer synchronized. So, on power up I'd like to put a comparison check on the J7 & J8, and report the un-synchronoused condition. Any place in the system variables I can get J8 value? (Sorry if this is detailed in another thread, a quick search didn't yield anything).
    Thanks, Jeff
  • Go to Best Answer
  • jstolaruk
    16
    189
    • July 7, 2023 at 7:24 PM
    Sadly, $scr_grp.$mch_ang doesn't give me the value of the slaved axis, only the master (J7 updates but J8 does not). I scoured the $DUAL_DRIVE variables where the master/slave relationship is defined but no luck there either.
  • dha
    28
    397
    • July 28, 2023 at 12:06 PM
    • Best Answer
    You can use
    $SV_INFO[1].$AXIS_POS[7]
    $SV_INFO[1].$AXIS_POS[8]
  • jstolaruk
    16
    189
    • July 31, 2023 at 8:22 PM
    Quote from dha
    You can use
    Thank you, I'll give that a look. -Jeff
