I TRIED THE MANUAL, BUT I CAN'T CHANGE THE R32TB PENDANT LANGUAGE.CAN YOU HELP ME?
INFO MANUAL :
http://www.geva-roboter.at/files/detailed_explanations_of_functions_and_operations.pdf
PAGE 103
R32TB
3.18 Operation of the initial-setting screen
There is the function of initial setting shown in the following.
(1)Setup of the display language... The character displayed on the T/B can be set to either Japanese or
English.
(2)Adjustment of contrast ............. The brightness of the screen of T/B can be adjusted in the 16 steps.
Operate this operation on the initial-setting screen displayed at turning on the control power in the condition
of pushing both of [F1] key and [F3] key of T/B.
(1) Set the display language
The character displayed on the T/B can be set to either Japanese or English.
1) Press the [F1] key in the initial-setting screen, and select "1. Configuration".
2) Press the [F1] key, and select "1. Default Language"
3) Display the "JPN" by [F1] or [F2] key, then language is set as Japanese. And, display the "ENG", then
language is set as English.
RT TOOLBOX
3.3. Changes in RT ToolBox3 Display Format
The display language and display style of RT ToolBox3 can be changed.
3.3.1. Changing the display language
The screen for changing the RT ToolBox3 display language can be changed by clicking the [Select Display Language] button in the [View] tab -> [View Settings] group on the ribbon.
When the display language has been changed, the display will be in the newly set language when RT ToolBox3 is next started up.
A list of languages that can be selected as follows.
Languages
English(英語)
Japanese(日本語)
Chinese Simplified(简体中文)
Chinese traditional(繁體中文)
Version 1.01B or later, when non-Japan has been selected, regardless of the "LNG" parameter setting, the controller turns on the language of communication in English. Sets the Japan and switch to Japan.
This function can be used with Version 1.01B or later of the CR800/750/700 series controller.
