Precise continuous movement for laser cutting
  • Thank you for your reply Jeremy.
    Frankly, this is not the problem. I don't even understand this function.
    This: str(int(min(100,max(1,zone_mm))))
    It just gives back the zone_mm parameter.
    Also, I don't want rounding. That's the whole point. We need precise movements, not rounded off movements. CNT will not be precise in this case.
  • Place your Ad here!
  • I see, I miss interpreted your need. I'll take another look at it.
    Still the rounding function should be the way I described it.
    It will, indeed, return the zone_mm, but within acceptable values for the robot controller.
    Between 1 and 100 in this case. I also convert it as an INT to remove decimal.
    Jeremy
    RoboDK - Simulation and Offline programming software for industrial and collaborative robots.
    Visit us at RoboDK.com
    Take a look at our tutorial videos on our YouTube channel.
