I need help with a replacement cable assembly, Miller Auto-Axcess(10 pin), RBT base, small-size RBT(27pin), 10m, part number: 152618-4. Does anyone know of a standard Motoman cross reference part number?
Help with cable assembly,152618-4 cross reference to similar cables
danc@rosemetal.com -
May 13, 2022 at 8:35 PM -
152618-4 is a standard Yaskawa part number for the cable you described. Cross reference a standard part number to what?
I understand the 152618-4 is a standard Yaskawa part number(only for this system build). What I am looking for is a replacement cable, cross reference numbers that may be common from other systems. Motoman is telling me 4- 6 week lead time to build a replacement.
What specs are you willing to adjust? Shorter cable, longer cable, different flying leads for wiring, number of pins?
