Hi All,
I have had quite a substantial problem on many of my robots regarding oil leaks throughout my career so far and I wanted to see if this issue is as prominent for others on this forum as it is for me and I am interested to find out from all units across the industry.
If so has it been a common occurrence? How has the support been for you from the robot manufacturer?
Have they solved the actual problem or just kicked it down the road? How demanding was the application you had the robot in?
Did you need to step in and provide your own fix e.g. pressure release etc?
I understand that they are mechanical systems and oil leaks are not something that can necessarily be 100% prevented in all applications but I am interested to see how certain brands weigh up against each other in that regard.
