hi,
if I want to change my current robot position by 3 mm, changing the config.dat or touch up option which one is better?
can someone please explain me both and how to do it by step by step.
I am using KR210 ULTRA C4 robot HMi version 8.3.3
hi,
Properly done, the end result will be the same either way. Touch up will be faster and easier if you have access to the robot.
The process of touch up is written out in sufficient detail in KUKA user manual.
thanks for your reply I can refer to the manual.
