Okay, so...
There's a program on our MA3100/DX100 cell that precedes my employment here, and to my knowledge hasn't been modified whatsoever. It's a basic hinge program, and for reference it's like a 90° angle where the program (which I will attach) welds four brackets along the base plane, then the part is removed and flipped and put back on the positioner to do the welds on the other plane, with a jig that allows absolutely zero chance for the operator (who also hasn't changed, by the by) to place the part on it improperly. Plus, he batches these at like 50 per go so it's not like he would suddenly forget how to do it in that run.
Here's the problem:
So there's 16 main welds in the program, 8 for each plane. We've never had a problem with it until about the new year, at which point our operator noticed that seemingly at random, the 9th weld (which is the first one in the second orientation of the part, the 2nd half of the program) will just, malfunction and attempt to start at an almost 2 inch offset. Nothing changes in the job, it pauses for the flip, he flips it, and resumes welding. It does a quick tac weld for each, which it does fine for this weld, but after the tac when it goes to COMARC the joint it just, starts way off. They're all comarc joints, so that part isn't out of the ordinary, just the haunted weld.
Some other things to note:
- The dude who programmed it no longer works here,
- It has never, ever malfunctioned before
- It is 100% always the same weld
- There is no consistency to when it will happen though the welder says it generally will be either at the beginning of a run or toward the end
- If the first one malfunctions, the rest of the 7 for that half will too by the same amount (there's no SFT instance though)
- No positional or major parameter data has changed on the robot\
- Nobody has proven that robot ghosts aren't real
Some oddities in the program, though. Like there are two questionable external axis command points right before the weld that screws up but the weld start point has the correct one. I'm giving you the original unedited program without the fixes I've tried so that it's not further corrupted by my 'helping.' You'll notice negative values for the comarc amplitude for some of the calls. This, too, baffles me as I'm not a physicist or mathematician and as far as I know for a symmetric waveform you pretty much always deal in absolute values, unless you're working with current which, I don't think applies here? I could be wrong. There's also a P variable defined in the header data which I'd never seen before and could very well be confusing the controller. It gets called in some weird ways, too.
Related followup question: Anybody know if there is a way to look at the code that COMARC uses? I couldn't find it, and my hex reader doesn't like yaskawa's code and doesn't tell me much.
If anyone likes mysteries or ghobots by all means, please check out the code. If you're using a text editor that has a line counter, the error is around the literal line 537, which is commented rather clearly as Weld 9.
Thanks!
