Advertising
7R80: disable Repositioning, exit PositionHold when it leaves the planned path
  • Good morning,
    In a RobotApplication app programmed in the workbench, I hold my effector at a still position with an infinite PositionHold() with duration = -1 second.
    If a high external force is applied to the effector during PositionHold, the safety system reacts normally according to the safety conf and goes into STOP1 -> OK.
    If a low external force is applied though, the robot leaves the PositionHold planned trajectory but allows the operator to resume it by pressing the PLAY button again. I would like to disable the repositioning/resuming feature. For instance, an exception could be raised when the robot leaves the planned path, then I would close the Robot Application so that it will necessarily start from the beginning next time.
    Do you know how i can achieve this?
