Hello, I'm having some trouble setting up my first vision simulation. I've done some searching, but I simply cannot figure out what this error means. When I try to execute the "Generate Camera Data" command, I get the error "Failure to generate camera setup CVIS-722 The camera specified cannot be found" (pic). This is after setting up the camera to connect to port 1 of my robot controller and executing a cold boot (pic) I'm not sure what else to try at this point, is there something in the teach pendant I have to enable for vision connectivity?
ROBOGUIDE Not detecting camera.
DownlaodAllTheFiles -
June 17, 2019 at 8:45 PM -
Alright, this error appears nowhere else I can find, so here's the solution that worked for me: you must shut down the TP Controller, and then close out of roboguide. After doing so, restart roboguide and if necessary, turn off the TP controller again, after doing so, delete the first camera, and re-create it. Plug it into the controller port as before, and you should be able to once again calibrate the camera without the error.
Hope this helps someone! -
IS THERE ANYWAY POSSIBLE YOU COIULD WAK ME THROUGH THIS OR CREATE A TO-DO
