Hey everyone,
I'm pairing the subject Turck I/O block to my robot using Ethernet I/P, and have successfully mapped out the 16 inputs/16 outputs to the controller. The issue is that I have to map 32 inputs and 32 outputs each because this device has diagnostics channels on the 1st (0) word. Has anyone every paired a device like this with and applied a word offset? I tried the analog settings starting at pt/channel 17 and mapping 1 word for input and output but that doesn't work. **GOAL: Reduce 1st word fluff in my I/O assignments**
Settings:
Vendor=48
Device Type=12
Product Code=14012
MajRev=2
MinRev=7
Size:
Input = 2 word
Output = 2 words
Assembly Instance:
Input = 103
Output = 104
Configuration = 106
Advanced:
I/O data type - 16 bit words
Set Target to Originator Transport Type: MULTICAST
