I get the following message during the compilation of my Karel program: "Code size exceeded maximum. Break program into separately translated units."
Have you ever seen this message?
How should I do to be able to compile my code?
I have received this error when my program gets too big. To fix this issue really depends on the size of your KAREL program. You may be able to just take the variables and constant declarations and put them in another .KL file and %Include that in your Karel program.
If that does not work, you may be able to take some of your routines from your karel program file and put them in another karel program file and then %Include them, or declare them FROM the other file.
Basically, you have to make your program smaller.
Hope this helps,
Thank you for your help, I will try something like that.
