Dear,
I have a error with a flexpendant IRC5 when the robot start wher'is this error
An unexpected error has occurred in Robotbootappl.exe
what is ? Ther'is possible to solve ?
Best regard's
Dear,
Best regard's
Have you tried changing the pendant?
Not sure this works on all versions off the teach pendant. It will work on newer ones at least.
With the robot controller up and running. Restart the teach pendant.
This can be done by pressing the Small button on the back of the teach pendant, inside the small hole.
The other way is to have someone help you disconnect the cable and plug it back in with the controller running.
When the teach pendant starts to boot up you need to hold down the "p1" and "stop" buttons. This will force the teach pendant to re-download an image from the controller and re-install itself.
Not sure this will fix you problem but worth a try.
