All
Has anyone ever tried to get the EtherNet/IP Safety (A05B-2600-R713) option to work using the RoboGuide with System Variable $EIP_ENBL_IO = 1?
I have been successfully in getting the Standard IO and EDA options to work between a GuardLogix 5069-L310ERMS2 and RoboGuide but cannot get the CIP-Safety to connect.
I am getting the following error on the connection tab in Logix Designer. I am using the AOP.
(Code 16#0114) Electronic Keying Mismatch: Electronic keying product code and/or vendor ID mismatch.
Per the Dual Check Safety Function Operator’s Manual I have Electronic Keying set to Exact Match and Revision set to 3.001.
I am getting the following error on the Teach Pendant in RoboGuide.
PRIO-230 EtherNet/IP Adapter Error (1)
PRIO-231 EtherNet/IP Adapter Idle
I am using a Robot Software V9.10 - R-30iB Plus.
DDT
