I read the manual (R-30iB_basic_operator_manual_[B-83284EN_05]) and I still need more info about the password function.
1. Is there a risk of overwriting the defaut config (INSTALL-PROGRAM-SETUP-OPERATOR) when importing an xml file or will it only have an impact on levels 3-7?
2. Is there a document where all the menus are listed? (I found a usefull link on this topic but I will appreciate if an official document from FANUC exists).
3. Is there a way to block some keys on the TP? For example STEP, HOLD.
4. For a specific level mode, I want to give the access only to: 4D position display and Alarm menu. Do I need to define access to all menus in the xml file (0 to all except these two) or is there a simpler way to do? I suppose that I shoud not block the access to menu-setup-password since I don't know how to switch to another user mode if I do so.
