Is it possible to change tool frame inside the same simulation program? What would be the best way of doing this?
When you create a simulation program, it also creates a .tp program you can access from the select menu on the teach pendant. You can add a tool frame change in this program. You won't see this reflected in the simulation program, but it runs from the teach pendant.
