After I used screenmaker to build a new page in IRC5, I got a problem
I tried to restore the system,and it did not work.
It's quite annoying that I need to acknowledge the message every time I switch on the machine
By the way how to delete the new page I built?
After use screenmaker, I got a problem
xiaoming123123 -
January 19, 2019 at 1:00 PM -
Delete the .dll from the controller HOME directory and then restart the flexpendant by pressing the button that is in the back of the pendant a while (there is a little hole on the back side).
Since RW6.0 flexpendant doesn't load/unload new screens at warm start.If that doesn't work, do a backup and then do a init start using the bootloader, then restore the backup.
Some times the robot controller doesn't restore ok and garbage config remains, doing an init start usually solves the problem.
