I am trying to setup a Miller Auto Continum 500 Ethernet/IP using Fanuc Ethernet/IP Scanner. I have the scanner setup and communicating but I can't setup the General interface. I have an R30iA controller and Miller Auto Access Enet is not an option at Controlled Start. I was told by Fanuc that I should be able to set this up using the General welder option, but using this I go into I/O setup it only gives Analog I/O for Voltage, Current, and Wire speed.
I guess the main question is can I change (via variables) the Analog I/O to Group I/O?
We have an R30iB which has Miller Auto Access Enet as an option at controlled start and the I/O is setup is with Group I/O.
ChipL
