Hi!
I will be using an external axis Fanuc motor, with continuous turn software, and use it almost lika a "high speed" rotating spindle. I want to monitor this and check that the real time speed is according to the value I put in.
We have set the system up so that 100%=3000 rpm. So if I set the speed to 100 % I would like to monitor in real time that the speed is 3000 rpm plus/minus some rpm's. If the speed is 50%=1500 rpm I want to check that it is 150 rpm and so on.
Preferably I would put this in a BG Logic program to have a constant check that the speed is ok.
Is this possible and do anyone have any suggestion how to do it?
Cheers! /Runis86
