Hello everybody.
I have this problem:
I just bought a PANAROBO VR-006A.
1) On power ON It asked me to reset all the axis, I did the reset procedure, but after OFF and ON same message.
Then I changed the six battery on the arm, I did the reset, but still same message. RESET again but still same message.
I tested the bigger battery inside the controller and it works fine, gives me 7.0 volts.
2) If I turned ON in OVERRUN mode, then push the SERVO button, and push TEACHING, the arms moves.
But when I try to move the FA motor it STOPS and gives me the A6010 error.
Does anybody knows where the problem comes from? Some memory board inside the controller is damaged?
Thank you.
