Hi all wondering if any one can advise me on connecting and powering the io board if fairly sure I’ve connected it correctly but the states lights won’t light up I’ve checked the output pins has 24v on all pins I haven’t configured any setting in the robot controller RW 5.15
Digital io dsqc 652
Pcavan -
September 7, 2018 at 3:56 AM -
The outputs won't light up until you set them.
The MS/NS LED's (from DeviceNET / Canbus) at the bottom left should light up either way assuming your bus is correctly wired / powered.
Do you have any other devices connected to the bus that are working or is this your only one ?
Hi I’ve spoken to abb today they told me to connect a 24v power supply to one node as there’s no power supply support from the devicenet card it works now after connect the power supply thanks lol for replying to post
