I have an Arcmate 50iL hooked up to an RJ3(I? It's the smaller cabinet, just says rj3 on the front). I'm pretty familiar with standard general-use fanucs (s-420i, 900ia, 2000ia), but I'm pretty lost on a couple things on this arcmate. It has no monitor function, so I'm not sure how to check if the plasma arc broke without programming a ridiculous number of individual input checks. Is there a way to do this using the welding utility? I see there is a way to monitor the weld arc, would this translate over? The plasma cutter is a powermax 125
Plasma cutting with Arcmate 50iL
FuhNooq -
July 13, 2018 at 2:09 PM -
I have an Arcmate 50iL hooked up to an RJ3(I? It's the smaller cabinet, just says rj3 on the front). I'm pretty familiar with standard general-use fanucs (s-420i, 900ia, 2000ia), but I'm pretty lost on a couple things on this arcmate. It has no monitor function, so I'm not sure how to check if the plasma arc broke without programming a ridiculous number of individual input checks. Is there a way to do this using the welding utility? I see there is a way to monitor the weld arc, would this translate over? The plasma cutter is a powermax 125Interested in more info on the welding utilities too. Not very familiar with the options. Anyone..
