Would it be possible to use a SharedPendant version of the KCP2 on a regular, non-RoboTeam KRC2 ed05(actually KRC3, but they're electrically identical)?
I'm looking for a KCP2 pendant, and I've found a relatively inexpensive offer, but only for KCP2-SP, not the regular 00-130-547 or 00-131-239.
Using a KCP2-SP ed05 pendant on a standard KRC2 ed05 system
Spirit532 -
June 16, 2018 at 7:09 AM -
It should work. Often I swap pendants from various robots and everything is OK.often this number changes due to the newer improved version changed a bit but always works without a problem.You just have to be careful not to buy it with the krc1 plugin.
It should work. Often I swap pendants from various robots and everything is OK.often this number changes due to the newer improved version changed a bit but always works without a problem.You just have to be careful not to buy it with the krc1 plugin.Ever tried the KCP2-SP? From what I understand, the physical buttons have changed function - there's a new set of symbols over the "drives off" button. I need a pendant specifically to make the ESC chain/physical buttons work, I don't care about the rest(qwerty keyboard/display).
Without a pendant my robot(KR3 w/ KRC3 controller) spits out 15 errors, all in some way pertaining to the missing pendant.
