Forgive me I’m a newbie. I have a DX200 bag stacking set up that was a palletizer. We replaced the palletizer with conveyor. The conveyor is about 150 mm taller than the palletizer. So I need to raise all bag drop points 150mm
What’s the easiest way to do this?
Pallet stacking modification
ThaHik -
March 17, 2018 at 8:42 PM -
The easiest way is to shift all the points using SFTON and SFTOFF Informal Instrucctions.
Declare a Position variable in required frame with the required shift amount (150mm in Z (Ex: Base Frame)
Go to the program where you need to raise all bag drop points:
SFTON P010 BF
MOVL
MOVL
// All Points Required to ShiftSFTOF
Thanks a lot! I’ll give it a go in the morning
