Can anybody help me out how to make TCP Correction in R-J3iB(120ib) Robot.
TCP Correction in 120IB(R-J3IB) Fanuc Robot
bidhan -
February 6, 2018 at 4:00 AM -
When you refer to TCPmate, are you talking about torchmate, the adjusment of A mig welding torch?
If you only have A few points that need adjusting in A program, I would recommend just reteaching those points. When you do A torchmate adjustment, you could end up having to touch up every point on every program installed on that robot. The torch mate plate is mounted on the robot base, Most times I have found that the tools, or fixtures are the things that are moving, especially in cold weather, or when the
temperature is changing drastically from morning to night. We only use the torch mate if we have to change A torch. Sometimes the easy fix turns out to be not so easy in the end. -
I have 100ib Fanuc robot also so i want a common software for 100ib as well as 120ib.
