Quote.i = 1 (local real variable .i) can only by used inside a program, it can not be monitored with list/type/save.
.$data = "abc" is a local string variable, cannot be monitored or saved.
$.data is an invalid variable name, will give an error.
POINT .test = here is a local transformation variable.
POINT .#test = here is a local joint variable
I knew that having a full stop turned globals into local variables, although I didnt know about the transformation variables. I also didn't know that only global variables could be changed outside of the program really helps, so thanks heaps for the info!!!
Quote$aa.paint.log[1] = " "
Thanks for that, my robot pendant is getting repaired at the moment, so the robot is not in operation, although as soon as it is in, I will report back to you to let you know how the program is running.
