Hello All,
I am trying to use a karel routine to load a *.stm file. I have tried the Load and Copy_load commands but I am not having any luck. Below is what I have been using:
LOAD ('UD1:\test\test.STM',1,STATUS)
COPY_FILE('UD1:\test\test.STM', 'MD:\', TRUE, TRUE, STATUS)
Both the commands compile fine with no problems, but when I run the pc file it locks up with the copy_file routine, and with load command it completes but nothing was loaded.
I am able to load the *.stm file via the teach pendent menus.
With the load command I am also able to load *.tp files, but no luck with the *.stm.
I have also tried directories other than MD:\, but no luck.
Any suggestions?
I am using spot tool + p34 and 8.3 software.
